Home » Sponsored » Pi Speakers » Looking for some Pi advice for theater ... (4pi vs 7pi)
Re: Looking for some Pi advice for theater ... [message #75238 is a reply to message #75236] Mon, 14 January 2013 14:26 Go to previous messageGo to previous message
AlphaG is currently offline  AlphaG
Great to hear that the cornerhorns would be feasible in the space. If you look at the plan carefully you will see a corner molding trim in the front of the proscenium/stage where I was planning on placing the cornerhorns. Hopefully that is where you thought I would be placing them. While the side walls of the room are relatively unobstructed, I am unsure as to how the acoustics would be affected by the opening for the screen. There is a short wall just behind that area where the cornerhorn would be, but towards the middle of the room, it opens up where the screen is. Will this be a problem?
I can likely soffit mount a 4pi in the middle of the speaker wall for the center channel.
I will then use a big summed mono sub up front and two summed mono reinforcement subs in the back to help with lower bass modal dips.
Previous Topic: Pi 1 plans please
Next Topic: Old veneer method, new to me...and it worked!
Current Time: Fri Nov 06 05:13:17 CST 2026
