Home » Sponsored » Pi Speakers » 3-Pi directivity
3-Pi directivity [message #75222] Sat, 12 January 2013 09:57 Go to next message
Hi Wayne,
I was looking at the horizontal dispersion curves for the 3 Pi, and it looks like the 90deg directivity control doesn't start until 2kHz. Should the directivity ideally start at a lower frequency (like the 4-Pi)?
Thanks,
Darrell
Re: 3-Pi directivity [message #75227 is a reply to message #75222] Sat, 12 January 2013 22:38 Go to previous messageGo to next message
I think what you're seeing is the wide-angle off-axis curves fall off more rapidly above 2kHz. It is apparent in the 50° response curve, and while they aren't shown, this is even more noticeable in the response curves taken further off-axis, outside the flare wall angle. But up to +/-45°, the off-axis curves fall off at pretty much the same rate, which is a signature of constant directivity.
Woofer beamwidth narrows to 90° around 1.2kHz, and the waveguide is starting to gain directivity control in this region too. I'd say it has full control by 1.5kHz or so, and horizontal directivity becomes constant 90° above that point.
Re: 3-Pi directivity [message #75228 is a reply to message #75227] Sun, 13 January 2013 13:04 Go to previous messageGo to next message
Does the 50deg curve in the plots represent +/-25deg or+/-50deg?
Re: 3-Pi directivity [message #75230 is a reply to message #75228] Sun, 13 January 2013 15:59 Go to previous messageGo to next message
That's +/-50°, marking the edges of a 100° arc.
Re: 3-Pi directivity [message #75231 is a reply to message #75230] Sun, 13 January 2013 16:48 Go to previous message
OK, I see now... I must have been looking at the wrong plots before.
Previous Topic: Anyone In The Western New York Area With 4 Pi's
Next Topic: Pi 1 plans please
Current Time: Fri Nov 13 01:45:45 CST 2026
