Home » Sponsored » Pi Speakers » 2Pi Coil across woofer?
2Pi Coil across woofer? [message #75212] Fri, 11 January 2013 11:01 Go to next message
I've got a schematic that almost looks like the coil is across the woofer and tweeter and doesn't show a series cap on the tweeter.
Could it be so old it's for the Piezo version?
The coil is in parallel on the Woof and the cap in series with the + Tweeter, right?
Re: 2Pi Coil across woofer? [message #75213 is a reply to message #75212] Fri, 11 January 2013 12:08 Go to previous messageGo to next message
There has always been a 0.5mH coil in series with the woofer, even back when we were running piezos. It's inline on the "+" wire. So that's probably the coil you're talking about. There was no capacitor in either the woofer or tweeter circuit on the old piezo models.
The tweeter circuit now has a series 10uF capacitor, and a shunt 16Ω resistor. So put the resistor directly across the tweeter leads, and put the capacitor inline on the "+" wire.
Re: 2Pi Coil across woofer? [message #75214 is a reply to message #75212] Fri, 11 January 2013 12:35 Go to previous message
Excellent!
Previous Topic: Factory refurbished JBL 2226H
Next Topic: Anyone In The Western New York Area With 4 Pi's
Current Time: Mon Nov 23 12:31:41 CST 2026
