Home » Sponsored » Pi Speakers » 3pi, smaller cab possible?
| Re: 3pi, smaller cab possible? [message #75059 is a reply to message #68434] |
Thu, 27 December 2012 17:04   |
zheka
Messages: 80 Registered: June 2012 Location: Chicago burbs
Viscount |
| Wayne Parham wrote on Sat, 02 July 2011 10:32 |
You can route to recess the woofer and the tweeter or surface mount both of them. Just don't do one and not the other. As long as they are both flush or routed on the baffle, their depth (distance from the listener) the same, i.e. one won't be further than the other, which would angle the forward lobe up or down.
Also, maintain the same vertical distance between the woofer and tweeter. For example, don't move the tweeter up outside the box unless you move the woofer up a distance to match. I don't think that's in the cards for you, but it might be worth saying, just in case.
Wayne,
Is it important to keep width of the baffle the same as on the original 3Pi?
thank you
By: smokarz on Thu, 23 June 2011 18:27
By: smokarz on Thu, 23 June 2011 18:51
By: smokarz on Thu, 30 June 2011 07:51
By: smokarz on Thu, 30 June 2011 09:57
By: smokarz on Sat, 02 July 2011 09:39
By: zheka on Thu, 27 December 2012 17:04
By: zheka on Thu, 27 December 2012 19:37
By: smokarz on Sat, 02 July 2011 11:22
Current Time: Tue Nov 03 05:10:01 CST 2026
