| Sound Isolation Preferences [message #73818] |
Fri, 14 September 2012 09:49  |
audioaudio90
Messages: 623 Registered: October 2010
Illuminati (1st Degree) |
How isolated do you like your home to be from outside sounds? If I'm recording, I want it as isolated as possible, of course, but otherwise, I throw open the windows so I can hear what's going on outside. It makes me feel more like I'm part of the neighborhood around me instead of shut away.
| Re: Sound Isolation Preferences [message #74007 is a reply to message #74004] |
Tue, 02 October 2012 10:38  |
Messages: 19105 Registered: January 2001
I don't really have any problem with isolating myself from neighbors because I'm in a single-family home. Back when I was an apartment dweller, it was a problem but really, there was no resolution. I just had to "keep it down" and live with the occasional noise from neighbors. Now that I'm in a home, the neighbors almost never bother me and I get no real outside sounds except for unusual events.
I think probably I'm more likely to be loud than my neighbors, but even that isn't usually an issue. I do have a Crown amp capable of 2400 watts though, and occasionally I'll put the petal to the metal, for testing or "just because". But that doesn't happen that often, really, I usually am running ten watts of SET power, which is plenty loud but not so much that neighbors would be annoyed.
