Silas Messages: 12 Registered: August 2012 Location: Kirkland, WA
What is the reason behind mounting the crossover components to a board, and then mounting the board to the cabinet? Couldn't I just mount the components to the cabinet directly, a la below?
mantha3 Messages: 72 Registered: May 2012 Location: Lino Lakes, MN
The board just makes it easier... Easier to do the x-over build and use the soldering iron. I like to use a 1/4" piece of something that I can drill holes in. Zip tie on Caps, Inducers since they are heavy... Goop em with silicone...
You can do what you are thinking direct and not use a board.
Ahhh, that is what I was thinking.
I did notice in the X-Over schematic by Wayne it mentions that this resistor R3 is "Mounted off board". Is this due to heat or something?
I'm going to be building soon and the X Over is something I'll do soon. Doing the 5 resistors like you will save some $$$ so I think I'll copy you on this.
Keep posting build stuff/photos. I'll do the same.
Will do. I'm actually keeping a build thread on AVS, titled something like "JBL and 4Pi theater...college style!" I won't link to it, but you can search for it if you like. PM me if you have any questions.
Wayne Parham Messages: 19103 Registered: January 2001
Sorry I missed this earlier:
mantha3 wrote on Tue, 11 September 2012 07:55
The R3 Zobel resistor we provide in the kits is packaged in a large aluminum block which serves both as a heat sink dissipator and as a mounting block. Our crossover PCB has a connector for this resistor, which is mounted off-board. We mount the crossover and Zobel resistor on the inside of the cabinet, directly on the bottom using a gasket to prevent vibration.
