Home » Sponsored » Pi Speakers » Repair JBL 2226H cone?
Re: Repair JBL 2226H cone [message #73669 is a reply to message #73658] Sat, 25 August 2012 06:19 Go to previous messageGo to previous message
Maxjr is currently offline  Maxjr
If you're buying another driver from the same seller, I would make sure they use adequate packaging/padding and insure it from loss and damage. When I purchased my JBLs, the seller screwed the driver to a half inch plywood larger than it's 15" diameter to protect it's face. He then bought solid styrofoam to pad all around the inside of the cardboard box. The drivers arrived perfectly and made the trip over the Pacific Ocean safely.
Previous Topic: How much duratex to cover three 4Pi's?
Next Topic: 3 Pi Plans
Current Time: Mon Nov 09 10:24:04 CST 2026
