Home » Sponsored » Pi Speakers » H290C dimensions (dimensions for the recessed cutout)
Re: H290C dimensions [message #73439 is a reply to message #73438] Tue, 31 July 2012 17:18 Go to previous messageGo to previous message
zheka wrote on Tue, 31 July 2012 16:48
If I want to flush mount, should I use 1" MDF panel for the front baffle or 3/4" panel is adequate in your opinion? Given that the recess is 1/4" deep.
What I like cabinetmakers to do is to cut a ring that surrounds the baffle cutout both for the midwoofer and tweeter. This ring can be cut from scrap wood, and is only there to provide some extra thickness in the area where the router cuts into the baffle. Glue it in place behind the baffle, and install the T-Nuts or threaded inserts into it.
Previous Topic: Speaker placement and wavefront launch
Next Topic: Spectral decay time of HF drivers
Current Time: Tue Oct 20 14:46:36 CDT 2026
