Home » Sponsored » Pi Speakers » H290C dimensions (dimensions for the recessed cutout)
H290C dimensions [message #73414] Mon, 30 July 2012 13:28 Go to next message
Hi Wayne,
I thought I'd start working on the cabinets while waiting for the horns and crossovers.
I'd like to set the H290C in a recessed cutout. Is there any way to get proper dimensions for this?
Thank you.
Re: H290C dimensions [message #73415 is a reply to message #73414] Mon, 30 July 2012 14:18 Go to previous messageGo to next message
The outside dimensions of the H290C are 11.63" wide x 6.56" tall x 5.90" deep. Most of it is 0.25" thick, although some portions are thicker. The front "lip" is 0.25" thick; Driver mounting bracket is a little thicker. Corners are radiused at 0.8". That's what you would cut into the baffle with a router for a flush mount.
Re: H290C dimensions [message #73416 is a reply to message #73415] Mon, 30 July 2012 14:36 Go to previous messageGo to next message
Perfect.
Thank you!
Re: H290C dimensions [message #73418 is a reply to message #73416] Mon, 30 July 2012 16:20 Go to previous messageGo to next message
Hi, Egads, how did they come up with those dimensions? Neither a standard US nor metric?
Re: H290C dimensions [message #73420 is a reply to message #73418] Mon, 30 July 2012 22:43 Go to previous messageGo to next message
Laughing It does seem odd dimensions at first glance, but they're really not so weird - I just wrote them in decimals and rounded to the hundredths. If Жека will be routing flush, he'll likely add 0.1" anyway. That way it won't have to be tapped in or pried out.
But said in fractional inches, the dimensions are 11-5/8" wide x 6-9/16" tall and 1/4" thick.
I wanted to make the baffle cutout an exact match for the old H290 horn so the H290C would be a bolt-on upgrade for existing speaker owners. The H290C fits right in the same router groove, so flush mounted speakers won't have to be rebuilt. No change to bolt-pattern either. The baffle cutout has to be made slightly larger, because for performance reasons, the H290C requires a 10.5" x 5" baffle cutout. But that can be accomplished with just a few strokes of a four-in-hand, rasp or file. It fits right in.
icon14.gif  Re: H290C dimensions [message #73424 is a reply to message #73420] Mon, 30 July 2012 23:38 Go to previous messageGo to next message
You know your Cyrillic, don't you, Wayne? Wink
Re: H290C dimensions [message #73426 is a reply to message #73424] Tue, 31 July 2012 07:20 Go to previous messageGo to next message
Да, конечно, чуть-чуть. Smile
Re: H290C dimensions [message #73429 is a reply to message #73426] Tue, 31 July 2012 10:15 Go to previous messageGo to next message
Fractions.... what are they Laughing I knew Cyrillic, kind of cute in a different sort of way Shocked
Thanks for the info, it never occurred to me that they use fractional inches.
Re: H290C dimensions [message #73432 is a reply to message #73429] Tue, 31 July 2012 10:44 Go to previous messageGo to next message
The dimensions don't really have anything to do with Cyrillic. Russians use metric measurements for the most part, but the H290C dimensions weren't affected by that. They aren't metric measurements.
They are sort of oddball dimensions, I guess, not a major multiple of a half-inch or something like that. But again, I wanted to make the H290C be a drop-in replacement for the older H290, which it supercedes.
Re: H290C dimensions [message #73438 is a reply to message #73414] Tue, 31 July 2012 16:48 Go to previous messageGo to previous message
Wayne,
If I want to flush mount, should I use 1" MDF panel for the front baffle or 3/4" panel is adequate in your opinion? Given that the recess is 1/4" deep.
Thanks again!
Previous Topic: Speaker placement and wavefront launch
Next Topic: Spectral decay time of HF drivers
Current Time: Sat Oct 31 04:08:50 CDT 2026
