Home » Sponsored » Pi Speakers » H290C Horn/Waveguide (Upgrade for the obsolete Eminence H290)
Re: H290C Horn/Waveguide [message #73437 is a reply to message #73435] Tue, 31 July 2012 15:35 Go to previous messageGo to next message
blvdre is currently offline  blvdre
mantha3 wrote on Tue, 31 July 2012 14:28
I have the Eminence horns... I have not started the build. I can't return the horns I have... Tempting to buy yours anyway.
Shoot!
I was able to sell mine on the parts express forum. Give it a shot, maybe you'll get lucky.
In other news, my new H290C horns are on their way Smile
Re: H290C Horn/Waveguide [message #73549 is a reply to message #71929] Thu, 09 August 2012 10:38 Go to previous messageGo to next message
Some have asked why it is important to maintain 90° beamwidth in the horizontal, and why 100° or more is less desirable. For example, one of our friends here recently evaluated another similar waveguide/horn with ~100° coverage. The other horn was touted as a 90° waveguide, but all measurements pointed to it having at least 100° beamwidth in the horizontal. It became somewhat of a point of contention, with the other horn/waveguide proponents reverting to an argument of "how much does it matter anyway?"
So what is the difference between 90° beamwidth and a little more, say 100° or 110°? What's wrong with a slightly wider pattern in the horizontal? How much does it really matter?
If the speaker were outdoors or in a very wide open space, I would find nothing wrong with the wider pattern. With no boundaries to worry about, I almost don't care what the coverage pattern is. But indoors, in a home hifi environment, the whole point of controlled directivity is to reduce early reflections from the nearest walls. I mean, why bother with having a waveguide/horn at all if your coverage pattern allows a significant amount of energy to be reflected off the side walls?
The sound radiated by a horn/waveguide doesn't end abruptly at the beamwidth "edge". Beamwidth is defined as the angle between the directions on either side of the forward axis, at which the intensity of the sound pressure level drops to one-half the value it has on the forward axis. That's only -6dB down, so sound definitely radiates outside this coverage pattern.
The goals are to provide uniform coverage within the desired beamwidth and to limit radiation outside this angle, to reduce unwanted reflections. So if I were to have to choose between being a "smidge" inside or outside the goal, I'd definitely lean towards being slightly tighter than wider. I'd rather have constant directivity through an 80° horizontal arc than 100° beamwidth for this application.
One shouldn't go too far with this, because too-narrow beamwidth is unnatural too. The square corners of our living spaces make 90° beamwidth a very natural coverage angle. But again, we certainly don't want coverage wider than 90°, because that increases reflections and reduces the benefits of controlled directivity. So I think a good target for horizontal beamwidth is to stay in the 80° to 90° range.
This is particularly important in a constant directivity cornerhorn. The bass bin and midhorn are within 1/4λ from the adjacent walls, so there is no self-interference. The walls become part of the horn, a source constraint boundary rather than a reflector. But the tweeter horn/waveguide is further than 1/4λ, because at high frequencies, wavelengths are short. So it is important that the waveguide beamwidth be 90°, matching the angle formed by the room's corner. A wider beamwidth would illuminate the walls and cause excessive reflections.
Even in a matched directivity two-way speaker, the extra beamwidth is unwanted. When the forward axes are crossed, toe-in at 45°, the edges of the pattern run parallel to the adjacent walls, just like cornerhorns but usually a little further away. The wall behind the speakers isn't usually all that far though - often just a few feet - and you really don't want a lot of off-axis energy to reflect off that wall. Using a 90° horn/waveguide ensures that sound directed at this wall is at least -6dB, even at a grazing angle, and more attenuated at larger angle of incidence. So this is the best configuration, in my opinion.
Re: H290C Horn/Waveguide [message #73597 is a reply to message #73549] Thu, 16 August 2012 07:42 Go to previous messageGo to next message
Maxjr is currently offline  Maxjr
Wayne,
I'd like to purchase a pair of these bolt on upgrades and replace the current Eminence H290 horns I have in my fully upgraded 4Pis. I have two questions regarding the new H290C:
1) Are there any changes needed to be done on my current crossovers? I can modify them, no problem. I'm just curious.
2) What audible differences could be expected when I compare the H290 to the H290C head-to-head with everything else remaining the same (JBL driver, crossovers, DE250, speaker enclosure, listening environment, and music)
Thanks for your time and all your efforts!
Re: H290C Horn/Waveguide [message #73599 is a reply to message #73597] Thu, 16 August 2012 10:12 Go to previous messageGo to next message
The H290C was designed from the start to be a bolt-on upgrade, that would require a minimum of crossover changes. The acoustic centers are in the same place and the patterns are similar, so the pre-2012 crossover used with the old H290 horn can be used and the primary lobe is forward and centered. But the upgraded H290C waveguide benefits from an upgraded crossover that has different values in a couple locations. Its impedance curve is different, necessitating the removal of capacitor C1 and installation of 16Ω resistor Rs. Check the schematic and board layout to identify and locate these components.
The π crossover uses a specialized π pad for its attenuator and top-octave compensation. It provides three functions, 1. To provide full-band attenuation, 2. To provide mass-rolloff compensation in the top-octave and 3. To provide specific damping for the core-splitter, which sets the SPL level of the crossover region independently of the midband. This network provides maximum flexibility, allowing the low, medium and high frequency ranges of the tweeter's transfer function to be set independently.
This network is created by components R1/R2 and the compression driver itself. In many cases, the output shunt leg of the π network is provided solely by the compression driver, and no extra shunt is required. But in the case of the H290C, a shunt resistor Rs is used.
The input leg R2 sets the load on the core splitter, which sets the damping. High levels of damping (low resistor values) brings down the SPL in the crossover region. Low levels of damping (high resistor values) increase SPL in the crossover region. The attenuator R1 sets the midband SPL level, and interacts with the output leg, providing mass-rolloff compensation. Optional components C1 and Rs are used to further tailor the response.
As for audible differences, remember that I always found the old H290 horn to a pretty good part, and didn't change it even when several new waveguide products began to enter the market. I found it to be better than most of the so-called waveguides out there, for one reason or another. The only thing I really didn't like about it was the edge at the mouth. I would have preferred it to have a rounded lip. But that's probably not audible, really. Constant directivity horns with sharp edges in the throat are audibly harsh and "spitty", and I think the edge at the waistbanding expansion in some CD horns also contributes to that somewhat. But it doesn't seem to be so much the case with horns having their only edge at the lip, like the old H290 had. I suspect distance from the throat matters most, and so an edge right at the mouth was least objectionable. Still, I prefer a gentle radius at the mouth, making the horn smooth everywhere.
Of course, the basic flare profile of the H290 is different too. The new H290C uses an OSEC flare profile, which is the shape that best transforms a plane wave into a spherical wave section without "fracturing" it. The wavefront expansion is at right angles to the wall at all points through the horn. Other shapes cause it to twist and bend as it progresses down the throat, making modes or "pockets" of distortion. The wavefront is slightly distorted as it travels down the throat of any other shape. So the oblate spheroidal profile is the perfect shape because it allows the wavefront to pass through the horn without distortion.
How audible is this? How much distortion of the wavefront is too much?
I don't know the answer to that question. At this point, I don't think anyone does. I know that the OSEC shape is mathematically correct, so it's at the "best" end of the scale. I also know that horns with diffraction slots in their throats are just the opposite, audibly harsh and spitty at the "worst" end of the scale. In between are the horns with other shapes.
In my experience, the biggest thing is to stay away from horns with sharp edges in them, particularly those close to the throat. If the horn is gently radiused from throat to mouth and holds the right patern without sharp edges, it's a 90% good horn, at least. The ultimate horn uses a pure OS/EC flare, and this is what the H290C is.
Re: H290C Horn/Waveguide [message #73600 is a reply to message #71929] Thu, 16 August 2012 14:11 Go to previous messageGo to next message
Thank you so much for that thorough response. I look forward to trying out the new H290C horns.
Re: H290C Horn/Waveguide [message #73616 is a reply to message #73600] Sat, 18 August 2012 14:35 Go to previous messageGo to next message
Hi All, I got the horns in and they are huge improvement over the H295s I had in there already (got them as the original 290s were out of stock and delayed back order). Well worth the effort to put them in. Smile
Re: H290C Horn/Waveguide [message #73632 is a reply to message #73616] Wed, 22 August 2012 22:48 Go to previous messageGo to next message
I just ordered my pair! I can't wait to try them out Very Happy
Re: H290C Horn/Waveguide [message #73682 is a reply to message #71929] Sun, 26 August 2012 23:28 Go to previous messageGo to next message
Quiet_Storm is currently offline  Quiet_Storm
Wayne, I'm considering upgrading to the H290Cs on my 4 pis. This thread has me hooked!
By the way, I've been loving my 4 pis and 3 pi subwoofers. I don't think anyone's left my apartment unimpressed. However, now I have a bit of upgrade-itis plus I'm considering a build for my dad, so I might try to knock both out in one purchase.
Also not to threadjack too badly, but I'd like to get your thoughts on the best speakers for my dad. He has an entertainment center in a corner that is closely flanked by his speakers. Based on this limited arrangement (and no room for flanking subs), I'm thinking 2 pi towers might be the way to go. What do you think?
Re: H290C Horn/Waveguide [message #73684 is a reply to message #73682] Mon, 27 August 2012 08:10 Go to previous messageGo to next message
Quiet_Storm wrote on Sun, 26 August 2012 23:28
I like two π towers, and use them for my bedroom system. It is setup kind of like you described.
Re: H290C Horn/Waveguide [message #73761 is a reply to message #73684] Sat, 08 September 2012 13:48 Go to previous messageGo to previous message
Wayne, looks like the H290C waveguides will be here Monday, though UPS says they are in NY right now! Mad
Until I get my woofers for the eventual 3Pi, I intend to set up the H290Cs in my home rig.
The home rig uses the 4Pi crossover/DE250/JBL 123A-1.
I have added 20dB attenuation from your chart plus an LPad for more attenuation and adjust-ability. Currently running QSC waveguides.
Previous Topic: 4pi flat pack, Rhino Line
Next Topic: 3Pi and 4Pi Plans Request
Current Time: Sun Oct 25 11:15:04 CDT 2026
