Home » Audio » Speaker » Reusing Speaker boxes!!!
Re: Reusing Speaker boxes!!! [message #73304 is a reply to message #73303] Mon, 16 July 2012 15:42 Go to previous messageGo to previous message
You can use different drivers, but there is almost never a drop-in replacement part that gives the same results. That doesn't necessarily mean the replacement part you choose is of lesser quality, it could be much better and still not give the same results. The reason is each model driver has different characteristics that interact together with the other parts in the system. So the bottom line is unless you are prepared to do some design work, it is probably better that you stick with stock replacement parts.
Previous Topic: New Project - The DR912a Line Arrays
Next Topic: iFish and iDog
Current Time: Tue Nov 03 14:24:05 CST 2026
