Home » Sponsored » Pi Speakers » 4PI Cabinet plans / question
4PI Cabinet plans / question [message #73067] Thu, 21 June 2012 01:07 Go to previous message
thatsnasty is currently offline  thatsnasty
Hey Wayne, I was wondering if you could send me the cabinet plans?
Smile
I have a couple quick questions in regards to assembling them as well.
Do the plans include a terminal cut-outs? Should the terminals just be standard red/black if not? ( I won't be bi-amping )
Will the $125 pre-assembled x-over work fine with the 2226h? I assume you can upgrade components as well if needed.
Reason being is I just got 2x 2226's from the bay at a good price. They were both pulled from matching cabinets as well so they look to be legit / original cones.
I'm in the same boat about the CD as well. The other AVS'er posted about the Denovo-360 being a good replacement, so I'll most likely get that as well.
Edit: one more thing. If I build a 4pi center, can I build it sealed and ignore the port (similar to the other build thread in the listening room) and not have to worry? I figured since the 2226h works good sealed I'd only be sacrificing bass extension.
Cheers.
Previous Topic: 4pi Crossover Questions
Next Topic: Value of L1 on 7Pi schematic?
Current Time: Tue Nov 24 18:01:02 CST 2026
