Home » Sponsored » Pi Speakers » Eminence Delta 12LFA
Eminence Delta 12LFA [message #72992] Thu, 14 June 2012 07:12 Go to previous message
nottaway is currently offline  nottaway
Hi Wayne,
I'm building some high efficiency monitors. I have read your white paper and it was very informative. Thank you for sharing your knowlege on speaker design. I'm considering using the Eminence 12LFA woofer in my design and I had a couple questions since you have used it in your designs....
* What advantage does the Delta 12LFA have over the Delta 12 in your opinion?
* Without going into proprietary design territory did you find the 650Hz dip in Eminence's measurements needing treatment with crossover? Did it demonstrate this dip in a box as well?
Nicholas
Previous Topic: Line level or High level inputs for Subs w/ plate amps
Next Topic: 4 Pi L/R/C placement advice
Current Time: Sun Nov 29 02:01:05 CST 2026
