Home » Audio » Thermionic Emissions » Some test results on JJ 5751
Some test results on JJ 5751 [message #72921] Tue, 05 June 2012 08:56 Go to previous message
Aki is currently offline  Aki
Have been testing a batch of newly released JJ 5751, and came up with some test results that I thought I might share with folks here.
Visually, JJ 5751 is identical to JJ ECC83S. Same glass, same plate structure. Electrically, they are definitely different creatures.
The numbers below were from a batch of 20 JJ 5751, tested at Ip=1mA, Ep=200V. Average numbers from JAN GE 5751 and JJ ECC83S on the same tester are listed for comparison.
                JJ 5751      JAN GE 5751    JJ ECC83S
Conductance :    2000           1650          1800
   Mu:            82             75            95
From the numbers above, calculated plate resistance are similar between JJ 5751 and JAN 5751.
Of course, this is only a test at a particular operating point and not a full curve trace by any means. But you get a general idea as to how JJ 5751 would behave.
Previous Topic: Amps for Christmas?
Next Topic: New "Tube" Books
Current Time: Fri Nov 13 09:20:51 CST 2026
