| Re: Wood used in 4PI construction [message #72867 is a reply to message #72866] |
Wed, 30 May 2012 09:15   |
Messages: 19101 Registered: January 2001
The problem with plywood isn't sealing the corners, it's the possibility of voids between laminations. Where there are voids, there is the likelihood of debris in the voids, which causes the cabinet to buzz. Honestly, the only plywood I trust is baltic birch. Most others will have voids, and some are pretty bad.
If you aren't going to move the speakers a lot or use the speakers outdoors or in humid environments, I would suggest MDF. If they will be moved a lot (like sound reinforcement speakers) or if they might be subject to water or humidity, use baltic birch plywood. In either case, an attractive, high quality wood veneer can be applied for aesthetics.
