Home » Sponsored » Pi Speakers » Large Rubber "O" Ring with JBL 2226H
Re: Large Rubber "O" Ring with JBL 2226H [message #72262 is a reply to message #72260] Thu, 19 April 2012 19:01 Go to previous messageGo to previous message
Good. I purchased 1/16" thick sheet of cork material that I then cut to size. I think it will work well. I also purchased #10-32 hex head cap screws to replace the Phillips. I am pretty sure this is what you use as well. I also thought that "O" ring appeared to cause more problems than it fixed. I will use the cork for the woofer as well.
My only remaining issue now is fringe to figure out how to fasten the 15" Dayton Grills to the JBL woofer. :-/
Previous Topic: My Three Pi Speakers Finished
Next Topic: Grills for Eminence woofers, sound implications
Current Time: Thu Nov 05 16:54:37 CST 2026
