Home » Sponsored » Pi Speakers » Audition in Austin
Re: Audition in Austin [message #71973 is a reply to message #71972] Fri, 30 March 2012 13:47 Go to previous messageGo to previous message
Cones that have been exposed to sunlight get lighter in color like that. I've seen 'em turn almost white. It doesn't have to be direct sublight either - They'll get lighter even if they're exposed to indirect sunlight long enough, like in a sunroom or in a car. I suspect that's all that has happened, and I wouldn't be concerned if that's all that appears different.
But when in doubt, check it out - there are lots of cheap recones out there that look just like genuine parts but don't measure anywhere close.
Do not apply anything to either cone to change its color. If you do, you risk ruining the driver. It may look better, but it also may measure worse. You can't apply a product to the surface without changing the characteristics of the cone. There's nothing about that cone I want to change, so don't do it.
If the difference in color is bothersome, I might be inclined to expose the darker one to sunlight for a while until its color matches. This is a long process though, so if that's not something you want to do, just take 'em both to a place to see about reconing. They'll probably only have to do one, but it wouldn''t hurt to have them both checked. If you don't know who to trust, call David Miller at Speakerworks. He'll get you fixed up.
Previous Topic: 4pi vs 3pi plans
Next Topic: 4pi Commercial Dinner Theater Build
Current Time: Wed Oct 07 03:29:09 CDT 2026
