Home » Sponsored » Pi Speakers » Audition in Austin
Re: Audition in Austin [message #71903 is a reply to message #71899] Sat, 24 March 2012 19:25 Go to previous messageGo to next message
Got a box glued up, and dry fit.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4003-2.jpg
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4006.jpg
Here is the one were all waiting for. Smile
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4007.jpg
Re: Audition in Austin [message #71906 is a reply to message #71903] Sun, 25 March 2012 08:45 Go to previous messageGo to next message
Lookin' good!
Re: Audition in Austin [message #71908 is a reply to message #71906] Sun, 25 March 2012 18:30 Go to previous messageGo to next message
Improvision at its finest:
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002-4.jpg
Wayne you're right cabinets can be built in a weekend, but it is a lot of work. Smile
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4003-3.jpg
Re: Audition in Austin [message #71912 is a reply to message #71908] Sun, 25 March 2012 19:41 Go to previous messageGo to next message
I need to fill a few boo boo's, any recomendations??
Bondo? Elmers wood filler any good?
Re: Audition in Austin [message #71914 is a reply to message #66232] Mon, 26 March 2012 05:24 Go to previous messageGo to next message
Also do you remove the paper back on the insulation even for top and sides or just the brace?
Re: Audition in Austin [message #71917 is a reply to message #71908] Mon, 26 March 2012 08:06 Go to previous messageGo to next message
Remove the vapor barrier (paper backing) from the insulation before installing it. That goes for wall linings as well as the cross-section piece.
As for wood filler, we really want guys like Epstein to chime in here because they do more woodworking than I do. I know there are purpose-made wood fillers that I'd rather use to fill a hardwood, but I'm not sure that's the best for MDF. I can't imagine you'd go wrong with that stuff though.
Re: Audition in Austin [message #71919 is a reply to message #71917] Mon, 26 March 2012 09:40 Go to previous messageGo to next message
mgalusha is currently offline  mgalusha
I've used auto body filler for small areas of MDF and it worked well. Make sure the area is clean. Smile
Mike G.
Re: Audition in Austin [message #71963 is a reply to message #71919] Thu, 29 March 2012 20:06 Go to previous messageGo to next message
A little more progress, got the braces in and wiring set up. Decided to finish in a walnut veneer.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4008-1.jpg
The wife wanted a dark finish, so i give you dark walnut Pi4!
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4010-1.jpg
The baffle is a Duratek black crinkle finish, I like it. Might have to touch it up a little after all is said and done.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4012-1.jpg
Re: Audition in Austin [message #71964 is a reply to message #71963] Thu, 29 March 2012 20:29 Go to previous messageGo to next message
Lookin' good! Coming right along!
Re: Audition in Austin [message #71969 is a reply to message #71964] Fri, 30 March 2012 10:15 Go to previous messageGo to previous message
Wish the xo was built, but there sure look the part.
http://i59.photobucket.com/albums/g295/mrnick_2006/pi4002-5.jpg
Previous Topic: 4pi vs 3pi plans
Next Topic: 4pi Commercial Dinner Theater Build
Current Time: Sat Oct 24 18:50:36 CDT 2026
