Home » Sponsored » Pi Speakers » H290 bumps / texture inside of horn - ok to sand down to smooth?
Re: H290 bumps / texture inside of horn - ok to sand down to smooth? [message #71777 is a reply to message #71776] Wed, 14 March 2012 23:18 Go to previous messageGo to previous message
Maxjr is currently offline  Maxjr
Wayne Parham wrote on Wed, 14 March 2012 21:23
Yes, it's fine. Sand away!
The riser marks are the big bumps on the face. The little goosebumps you're talking about are just texture, a form of finish that hides surface irregularities. The riser marks are actually formed where the plastic is injected into the mold. Both can be finish-sanded smooth. Just be careful and don't go so far that the throat opens up. Only take off enough to remove the texture and make 'em smooth.
That's great news! I'll try to keep the throat the same diameter. When you mention the face, are you referring to the area where the 6 bolt holes are? Also, is it enough to just use wood screws to mount the horn into the 3/4" ply, or should I use hurricane nuts and bolts (I'm using hurricane nuts and bolts for the 15" JBL.).
Previous Topic: Center Channel with 6pi Corner Horns
Next Topic: Let's talk about 4Pi Speaker Stands =p
Current Time: Tue Nov 03 12:56:30 CST 2026
