Home » Sponsored » Pi Speakers » H290 bumps / texture inside of horn - ok to sand down to smooth?
H290 bumps / texture inside of horn - ok to sand down to smooth? [message #71772] Wed, 14 March 2012 17:08 Go to previous message
Maxjr is currently offline  Maxjr
Hi Wayne,
Is it ok to sand down all of the small bumps / texture on the inside of the H290 horn? Or was it molded this way intentionally? My gut instinct tells me its ok to sand, but wanted to make sure with you first that it won't change anything. I just can't understand why Eminence didn't make it smooth like the back of the horn.
Also, I recall you mentioning removing riser marks on the H290 horn. Do you have a picture of where these are?
Previous Topic: Center Channel with 6pi Corner Horns
Next Topic: Let's talk about 4Pi Speaker Stands =p
Current Time: Tue Nov 03 10:31:16 CST 2026
