Home » Sponsored » Pi Speakers » Another Sub woofer Q&A
Re: Another Sub woofer Q&A [message #71140 is a reply to message #71139] Mon, 30 January 2012 14:29 Go to previous messageGo to next message
feket663 is currently offline  feket663
Wayne Parham wrote on Mon, 30 January 2012 21:09
I must level with you. That woofer isn't a sub. It might be a fine midwoofer, because it is tuned like so many others that have been designed to run in 75-150 liter boxes tuned to 35-40Hz. This has become a defacto standard tuning for prosound midwoofers, and it works great for mains where the woofer will be used down to 40Hz or 60Hz or so. But it's really not the best choice for use as a dedicated subwoofer.
I understand. I think I need collect some money for LAB12-s...
Re: Another Sub woofer Q&A [message #71142 is a reply to message #71140] Mon, 30 January 2012 15:59 Go to previous messageGo to next message
The LAB12 is a competent driver. And in North America, it is inexpensive too, so it's a good option. But if it is expensive where you are, don't hesitate to look for other options. Look at subs from Peerless or SEAS, for example.
Re: Another Sub woofer Q&A [message #71158 is a reply to message #71142] Tue, 31 January 2012 02:08 Go to previous messageGo to next message
Thanks for help! Finally I have a newbie question: Isn't problem, if I choose car subwoofer driver, like this:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/BoxesandParameters/GTO1214TD.pdf
Thx!
Re: Another Sub woofer Q&A [message #71159 is a reply to message #71158] Tue, 31 January 2012 08:02 Go to previous messageGo to next message
That's fine. A lot of the small sub drivers are used in cars.
Re: Another Sub woofer Q&A [message #71166 is a reply to message #71159] Tue, 31 January 2012 14:32 Go to previous message
Thanks Wayne!
Previous Topic: horns for a small room
Next Topic: Interesting sub on sale
Current Time: Wed Aug 19 15:29:53 CDT 2026
