Home » Sponsored » Pi Speakers » Subwoofer Crossover
Re: Subwoofer Crossover [message #71103 is a reply to message #71090] Wed, 25 January 2012 18:32 Go to previous messageGo to previous message
Any suggestions? I know you used to use a modified Pyle crossover, but I do not have the electronics skill required to do so.
I have looked at a miniDSP unit, cost is about $135 (more than I wanted to spend). However, if I go with a MiniDSP 2x4 (2 input, 4 output) and associated 2 way Advanced 2.1 plugin I should be able to set low and high pass filters for Left, right and mono subwoofer outputs (w/ Butterworth up to 8th order (6 to 48dB/oct); Linkwitz-Riley up to 8th order (12 to 48dB/oct); and Bessel - 2nd order). In addition, the unit has 6 parametric EQ bands per output, 6 EQ bands per input, Frequency, Gain, Q configurable, and Peak of Shelf (low/high). It is powered from the USB input used to program the box. Should be sufficient for my needs.
index.php?t=getfile&id=700&private=0
index.php?t=getfile&id=701&private=0
Does anyone here have experience with the unit? I know it is popular on AVSForum and other DIY websites.
VIRIBUS MARI VICTORIA
Previous Topic: May I have the enclosure plans for your 4Pi speaker?
Next Topic: Crossover upgrades
Current Time: Tue Nov 03 10:58:46 CST 2026
