Home » Audio » General » Parametric Equalizer (Who sells them)
Re: Parametric Equalizer [message #71100 is a reply to message #71052] Wed, 25 January 2012 16:54 Go to previous messageGo to previous message
AudioFred wrote on Fri, 20 January 2012 06:18
You will find them in pro audio equipment. Most have balanced or 1/4" inputs and outputs, so you would need to get some RCA/Balanced adapters. http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=210
In my experience the lower priced ones do effect the sound negatively. I tried the Behringer DEQ2496 and found the soundstage collapsed with it in the signal path. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-661
I finally settled on a dbx DriveRack PA+, which also functions as an active crossover, and it has a minimal effect on the sound quality in a mid priced system. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=246-171
If you want this for room correction it might be a good buy. If you want it to boost the midbass for a boomy subwoofer sound, buy an inexpensive boomy subwoofer instead.
Ouch, $500. And you say the $300 gave poor results. No, I don't want to adjust the base. Some fine adjustments in the mid and upper registers.
Previous Topic: Watches With MP3
Next Topic: Earbud Covers
Current Time: Mon Oct 26 15:25:06 CDT 2026
