Home » Audio » General » erratic cycling
erratic cycling [message #70353] Thu, 01 December 2011 12:09 Go to next message
rollingthunder6 is currently offline  rollingthunder6
i have a BIC 960 mulitiple play turntable.
of late, the cycle mechanism has become erratic: somtimes at the end of a record it cycles to the next record, and sometime not. there's no discernible pattern: for any given record, sometimes it will, and sometimes it won't.
this turntable is equipped w/ tonearm counterweight, tracking force adjustment, anti-skate force adjustment, cueing rate adjustment, stylus set-down adjustment, and pickup height adjustment. will fiddling w/ any of these solve the problem, or is there something inside that i need to fiddle with? or is it simply time to buy a new turntable? any advice/suggestins will be appreciated.
thank you.
Re: erratic cycling [message #70354 is a reply to message #70353] Thu, 01 December 2011 14:34 Go to previous message
Hi, Ask the question on the vinylengine forum and check the extensive data base on turntables. I suspect it just needs cleaning or lubrication. Smile
Previous Topic: Loud Headphones
Next Topic: Music Editing
Current Time: Thu Nov 12 05:52:25 CST 2026
