Home » Sponsored » Pi Speakers » Notes for the DIYer (Things to consider when designing a "waveguide" loudspeaker)
Re: Notes for the DIYer [message #70330 is a reply to message #70048] Tue, 29 November 2011 14:35 Go to previous message
As most of you know, I've been building CD/waveguide speakers like these for over 30 years. My first models all used a simple crossover, and we continued to build them that way through most of the 1980s. I always have tended to embrace Occam's Razor when designing circuits, especially loudspeaker crossovers. A couple early minimalist crossovers are described in my crossover document, as are other improved versions that followed it, including the current design:
The "Crossover Electronics 101" lab handout is also probably useful, in this regard. It is a related document, one I use at trade show seminars to help illustrate the principles used when designing crossovers for loudspeakers like these:
As I said, my first crossovers were minimalist designs and they remained that way for years. I was satisfied with them, not noticing their deficiencies for quite some time. You can make a good crossover with just a handful of parts, but I have learned that you can't make the best crossover for a waveguide speaker with just a handful of parts. There are a few reasons for this, which I will try to describe.
While I wouldn't suggest a minimalist crossover for a waveguide, I still would suggest a simple crossover for some speakers, like cone/dome monitors where the tweeter is designed with sufficient travel to allow relatively low frequency energy without stress. They don't have issues with phase plug interference, so as long as the suspension allows and the voice coil stays in the gap, there is little problem. A minimalist crossover works great for that kind of speaker.
Compression drivers on horn/waveguides are a different matter entirely. They don't respond well to minimalist crossovers for a variety of reasons. For one thing, the low-orders allow excessive excursion, which causes a compression driver to distort. The typical 1" exit compression driver is designed to be used with a ~1.5kHz crossover using third-order or higher slope. They just can't handle much low frequency energy at all. It isn't unusual to see a diaphragm contact the phase plug when driven hard, and it's real easy to drive 'em too hard with a shallow crossover slope. And even long before you see this kind of catastrophic damage, you'll see harmonic and intermodulation distortion rapidly rise.
It isn't like a dome tweeter either, where distortion rises proportional to excursion. It's more like a shelf - above horn cutoff, excursion is low so distortion is practically non-existent but below cutoff, excursion rises rapidly and distortion shoots straight up. Horn loading limits excursion above cutoff but below, the diaphragm is free to move. Sometimes is becomes dangerously underdamped, right as the horn transitions at cutoff, especially in conical horns and other CD designs.
With low-order crossover slopes, the amount of energy down low can be significant, so there is little to prevent the driver from over-excursion. Especially since the impedance spikes right around cutoff - a quarter-wave mode - which tends to leave the driver even more vulnerable just below that spike. You really don't want much energy presented to the driver below that point, because it usually makes intermittent ugly sounds and can be damaging.
This potential distortion problem is one of two things that conspire to make minimalist crossovers generally unacceptable for horn/waveguide speakers. The second thing is the interaction between drivers in the crossover region. This is one of the biggest challenges for the CD/waveguide loudspeaker designer - to develop a clean forward lobe that is not too thin in height and to limit the amount of sound outside the pattern. With this, there is the desire to limit the anomalous sound outside the pattern and I think that's where the designer's burden really lies. This is what separates the good speakers from the really great ones. It is the difference between a decent DIY project and a world-class loudspeaker. It's all in the shape and size of the forward lobe, and in the absence of nasties outside it.
Crossovers with low-order slopes have wider overlap bands than those with higher-order slopes. Where the typical fourth-order crossover will have adjacent drivers blended for about a quarter-octave, first and second-order slopes will blend for an octave or more. The nulls only form in the blended overlap region, so narrower overlap means narrower nulls. I have found that there seems to be a "sweet spot" between (electrical) second and fourth order, because it allows enough blending to provide a smooth phase transition for good summing but also not so much that it is excessively anomalous above and below the crossover point.
I wouldn't care if the nulls were wider as a result of low-order slopes. If that's all that happened, I might prefer lower-order slopes. It could be used to provide extra "directivity control" in the vertical down where the horn was too small to set the coverage angle. That's one of my design philosophies anyway - to set the nulls just outside the vertical pattern at HF. It sort of punctuates the pattern. If the nulls could be made an octave wide, then they could serve this purpose even better.
The traditional conical horn with 1:2 aspect ratio is twice as wide as it is tall, with horizontal angle that's about twice the vertical angle. This results in a horn that cannot provide pattern control in the vertical for almost two octaves above that which it provides control in the horizontal. So you can choose a horn that's larger than needed to set the horizontal pattern in order to get the vertical control to work at lower frequency. The problem is this also increases the height, increasing the vertical distance between sound sources, and ultimately reducing the height of the forward lobe. The nulls are drawn inward, cutting into the pattern. So an oversized horn isn't particularly useful.
A compromise is usually struck, one where the horn is sized to provide control in the horizontal, but allowing the vertical to lose control in the octave or two above cutoff. The vertical nulls from the driver interaction then cut into the widening pattern, limiting it at low frequencies near cutoff to approximately the same coverage angle as the HF beamwidth. These nulls are generally a few hundred Hertz wide, so they're a quarter to half octave at the typical ~1.2kHz crossover point. However, the 1:2 aspect horn/waveguide doesn't usually begin to gain pattern control in the vertical until 3kHz. So what we have is nulls limiting the beamwidth up to maybe 1.6kHz or so, and then an octave where it is wider, settling back into the desired vertical beamwidth above that.
It seems somewhat intuitive to think maybe the excess overlap of a low-order slope might give us wider nulls, cutting the edge of the pattern through a wider range. It could be used to augment pattern control through the region where the horn beamwidth widens in the vertical. But in practice, this is not the case. What actually happens is the nulls become very choppy. Instead of two clean notches at the crossover point, one above the center of the forward axis, the other below, what you get is a notch, then a big peak, then another notch, another peak, and so on. The peaks are actually more troublesome than the notches, because they can be really loud.
When the overlap region is too wide, interaction between drivers isn't clean. This is partially because of the shifting phase through the overlap region and sometimes partially because the off-axis response of the midwoofer isn't smooth. Summing is complex, and what usually (always) happens is major nulls form near the center of the crossover overlap region, and then large peaks and dips occur above and below the major nulls. Sometimes the peaks are very large and audible, and can become the most noticeable sound at certain angles. It's pretty bad when that happens.
If not too boring in this already too-long post, here's a little bit of empirical history to illustrate the roads I traveled to learn this:
In the 1980s, I was pretty happy with most of my designs and had almost concluded that they were a fait accompli. This was especially true of the constant directivity cornerhorns, because they just sounded so good. They were all very much like the line I still have today, except all crossovers were first or second-order.
But occasionally, I would notice a screeching sound in some vocals that I thought for a long time was caused by problems with vinyl. I was always meticulous with cleaning, and kept my cartridges anti-skate and set-down weight adjusted properly, but still, I thought the rare anomaly was from the albums. It sort of sounded like what I would expect from a damaged groove, a sort of intermittent screech on some material. You could go literally months and not hear it, but some material would do it every time.
That was one of my clues - the fact that some material did it consistently. Most times it was intermittent, but sometimes it always happened at the same place. The one I remember most distinctly was Dear Diary by the Moody Blues. The Leslie-modified vocals would exacerbate the problem and you could regularly hear it even at moderate volume levels.
As I said, I thought it was a problem with the source media until one day I realized I didn't hear it on another set of my smaller one π speakers that did not have compression drivers. After I noticed that, I took the one π speakers and set them side-by-side with my earliest model three π loudspeakers that had a compression driver, and played the same material through the same source and amp into each set of speakers. Sure enough, the one π's sounded fine but the three π's had the anomaly. I began to look for a cause right then and there.
Back then, I really didn't like compression drivers anyway. They didn't reach far into the top octave even with mass-rolloff compensation, and so I was in a sort of experimental phase with the whole DI-matched two-way concept. The earliest models, just prior, were all three-ways, using a cone midrange and a slot tweeter. Of course, they weren't able to provide uniform directivity, they were traditional loudspeakers. But the magic I heard from the cornerhorns compelled me to continue on this path and to make uniform directivity a design goal of all my loudspeakers. The horn mounted compression driver made this possible where nothing else would.
Most of my design tools were mathematical models. They were primitive by today's standards, barely more than formulas done by pen and paper. I wrote computer programs to help me work the mundane formulas, but they were all just providing single points of information. No graphics, no response curves. All just single-dimensional data-points. To find some kind of response (whether impedance, amplitude and/or phase), I would "run the numbers" several times, to make a sort of a "sweep".
I was also limited in measurement capability, having just an oscilloscope, signal generator and microphone. While I could make measurements of stepped sines, I really only had visibility to about a 3dB resolution and my patience level limited me to making measurements about every few hundred Hertz. Naturally, my charts were very course, and my visibility limited. I relied on my measurements mostly for finding trends. So I had poor visibility into this intermittent screeching problem, and had to hunt for a solution somewhat blindly.
Since the loudspeaker without the compression driver didn't do this, I considered it might be just a problem with compression drivers in general. After all, they were generally used for prosound use only. But it seemed worthwhile to explore different crossover configurations, and I found that crossing it higher in frequency or in slope made the problem go away. My conclusion then was that the problem was caused by excessive excursion.
Through the 1990s, I was able to make incremental improvements. Compression drivers got better, and better computerized design tools started becoming available too. Spice was available for the PC, and with it, I could graph transfer functions. My modeling tools gave me much better visibility. Then by the early 2000s, I was able to incorporate the Spice models with measurements, actually making digital crossovers that were configured using Spice models. That was huge, in that it let me make any sort of crossover I wanted, by simply describing it as a Spice model. Then a physical model exactly matched the mathematical model. The modeling tool became so good that I would say the model was an exact digital representation of the physical model.
By this time, I had very good visibility into what's going on. That's the state of the art today - DIYers have a large assortment of tools to work with. Computer modeling tools and measurement systems are inexpensive and very capable. But you still have to spend some time and know what to look for. There's a lot of sweat equity in a good loudspeaker design.
In hindsight, I'd have to say the audible anomalies in the crossover region caused by minimalist crossovers are as much due to the jagged vertical response off-axis above and below the crossover point as it is the over-excursion of the diaphragm. Both these things conspire to make a minimalist crossover untenable for waveguide loudspeakers with compression drivers. If you move the crossover point high enough that the compression driver is properly loaded, then the midwoofer is strained and directivity isn't well-matched. If you move crossover down to a more reasonable frequency band, then you get the screech from a strained compression driver, and the jagged off-axis peaks and dips above and below the nulls.
All this to say I wouldn't waste my time with a minimalist crossover in a waveguide loudspeaker. It isn't really an application of Occam's Razor. When you realize the complex acoustic and electrical impedance provided by the horn/driver combination is effectively a virtual circuit of dozens of components, the simple single component crossover becomes non-sequiter. It isn't the best solution.
Previous Topic: 4 Pi Cross over and design plans
Next Topic: 7pi plans
Current Time: Thu Nov 19 09:53:53 CST 2026
