Home » Audio » Speaker » Motorcycle Speakers
Re: Motorcycle Speakers [message #70174 is a reply to message #70173] Wed, 16 November 2011 13:10 Go to previous messageGo to previous message
Motorcycle speakers are pretty much worthless, except at stoplights. That said, your choices are largely determined by your fairing. Be sure to check the size required. Once you know the size, you can pick a speaker for it. They're usually the same as car speakers, or like Bruce said, marine speakers. It's more about size than anything else. So definitely, check the fairing. Might even ask the manufacturer of the fairing, to be sure the speaker you choose will fit.
Previous Topic: Speaker on Black Friday
Next Topic: Golden ratio for loudspeaker cabinets
Current Time: Wed Oct 21 23:00:21 CDT 2026
