Home » Sponsored » Pi Speakers » 4Pi (better late than never)
4Pi [message #70092] Fri, 11 November 2011 05:36 Go to next message
48h350 is currently offline  48h350
Hi Wayne , i purchased the components -2226H and 2426H in 2007 and finally i found the time ,in this last Australian winter, to build the speakers. the crossover is a 1600 Hz eminence with c5 and r3 removed ( see your document marked PDP 001-0011 )
I have one amplified SW ( Klipsch ) .
I am very impressed with the overall sound quality.
However , with some musical genres, i wish the speakers had more pronounced high notes.
I saw the comparison between the B&C 250 curve and the 2426H and it is self explanatory why you tend to favor the B&C.
Would it be feasible to modify the crossover and add a Beyma CP21F to handle the spectrum between 8KHz and 16 KHz. making the speaker a 3 way system ?
Or you would rather recommend replacing the 2426H with the B&C 250 and your new version of crossover?
Let me know what you think
Thanks again for designing a great pair of speakers
Massimo
Re: 4Pi [message #70093 is a reply to message #70092] Fri, 11 November 2011 07:59 Go to previous messageGo to next message
The 2426 definitely rolls off early. The DE250 provides greater extension. So I would definitely suggest upgrading the crossover and compression driver.
Re: 4Pi [message #70105 is a reply to message #70093] Sun, 13 November 2011 13:47 Go to previous messageGo to next message
galyons is currently offline  galyons
Hi Wayne,
Would you please resend the 4pi plans. My hard drive crashed and the back-up file is corrupted.
Thanks you,
Geary
geary.lyons@gmail.com
Re: 4Pi [message #70118 is a reply to message #70105] Sun, 13 November 2011 23:31 Go to previous message
You've got mail!
Previous Topic: Top portion of the 8Pi
Next Topic: Mid Horn Construction
Current Time: Sat Oct 24 19:06:28 CDT 2026
