Home » Sponsored » Pi Speakers » My kits arrived (towers)
Re: My kits arrived [message #70053 is a reply to message #70051] Mon, 07 November 2011 13:12 Go to previous messageGo to previous message
I like using black number 6 pan head screws. Every hardware store in town will have them, but usually not in black. If you can't find them in black, get the standard ones and paint the heads black after installation. That's how I always used to do it before I started buying the ones that already have a black finish.
About the cabinets and crossovers, I usually wire-tie the coil and cap to the cross-brace. If the cabinet panels are cut on a table saw with true edges and assembled with clamps, then you won't have any leaks, and no need to caulk the edges. But if you're unsure that your cabinet is airtight, it won't hurt to add a bead of silicon along the inside edges.
Previous Topic: 3 Pi plan request
Next Topic: drivers are a couple hours away
Current Time: Sat Oct 24 11:25:12 CDT 2026
