Home » Audio » Speaker » 3D Sound
Re: 3D Sound [message #69921 is a reply to message #69919] Fri, 28 October 2011 20:25 Go to previous messageGo to previous message
thannytoes is currently offline  thannytoes
You don't need any special recordings to achieve the effect, and I always leave the processor on. Mine has 3 buttons on the front: Injection Ratio (Normal/Theoretical); Listening Aperture (Narrow/Wide); On/Off. I leave them all on, all the time.
Try this: Put your speakers together, 2 inches apart, facing strait-forward for the time-being. Turn on the Holography and take a listen. After that, you can carefully toe the speakers in. The angle must be PERFECT, or you will get a lop-sided effect.
Of course, you don't need to use the synthesizer modes.
Let me know how it turns out!
Here is the C-9 manual if you want a thorough explanation.
http://thecarversite.com/manuals/files-manuals/Carver%20C-9%20owner%20manual.pdf
Previous Topic: Dipole Speakers (particularly ESL)
Next Topic: Constant Directivity Speakers Using DSP
Current Time: Thu Nov 19 01:46:07 CST 2026
