Home » Sponsored » Pi Speakers » AE Drivers
AE Drivers [message #69809] Sat, 15 October 2011 09:20 Go to next message
MerlinGS is currently offline  MerlinGS
Hi Wayne,
I have not started on my Pi 7's yet, but I was wondering, how difficult would it be to use AE drivers on this design? Would it make a difference or would there be an advantage to just doing the 15" or would using AE's in the 10" also be viable? Is there a reason you didn't provide the AE's as an alternative for the Pi4's and Pi7s?
Thanks
Re: AE Drivers [message #69810 is a reply to message #69809] Sat, 15 October 2011 10:12 Go to previous messageGo to next message
The seven π loudspeaker could probably be fitted with an AE TD15M, although I haven't tested it. The reason I think it would probably work is the (300Hz) crossover point is low enough that the woofer characteristics would almost certainly be similar. Almost all woofers act pretty much the same in this range. The source location within the cabinet is the same, so I expect standing waves to line up the same. For all these reasons, it is likely that a woofer swap in this model would work well.
This is not necessarily the case in the four π loudspeaker. I would expect crossover changes would be required in this model.
To expound a little bit - the TD15M is pretty much a drop-in replacement for the 2226 as far as T/S specs are concerned. It was designed to be a bolt-on replacement for many prosound drivers that have emulated this tuning. Kind of cool, really, that a pseudo-standard alignment emerged in the last couple decades.
What's potentially different is the behavior above about 500Hz. That's very specific to cone material and shape, including the dust cap. Impedance is also largely an issue, because most woofers have rising impedance due to voice coil inductance but the amount of rise and where it begins is widely different between models. So these things would need to be dialed in when using the TD15M in a two-way design. Keeps it from being a drop-in replacement for the four π model.
I am often asked about the differences between JBL 22xx and AE woofers, and why I didn't use an AE driver in the four π speaker. The answer is pretty simple: The JBL 2226 has been a long-time favorite of mine, and the four π speaker that uses it is mature, having been around for literally decades. It's a great speaker.
The three π model was designed to use the TD12S as its upgrade path so I could offer a model with an AE driver. I am very fond of this model too. Can't say which I prefer - they are both very fine.
I tend to try and refrain from giving my subjective opinions on the comparisons between the JBL 2226 used in the four π and seven π speakers and the AE TD12S used in the three π and six π speakers. I just think too highly of each of them. I don't hesitate to point out the benefits of midwoofers that have shorting rings, which is why I suggest the upgraded drivers over the stock ones. But once you get into the upgraded drivers, you're into the realm of what I consider to be the best speakers you can build or buy. It just doesn't get any better than that, both models are superb.
I sometimes make the comparison to cars. Which would you prefer, a Ferrari F40 or Porsche 959? Both are world class cars, both exceed 200MPH. It is like this with the fully upgraded models of π speakers too.
Re: AE Drivers [message #69812 is a reply to message #69810] Sat, 15 October 2011 12:07 Go to previous messageGo to next message
Thanks for the info Wayne. Regarding the 10" driver in the 7 Pi, is there any benefit in upgrading the driver to an AE, or is the stock sufficient in that size? Also, I have read a number of posts where you speak of your fondness for the Pi 3s and 4s, but I have not noticed much on the Pi 7. Although one of the reasons I was choosing the Pi 7 was aesthetic (I'm planning to use it in a stereo setup in the living room, where they are readily visible), I assumed there was some benefit to controlling the sound wave below 1K. In the context of stereo, how do you find the 4s and 7s compare (each with upgraded drivers where applicable)?
Thanks
Re: AE Drivers [message #69814 is a reply to message #69812] Sat, 15 October 2011 13:53 Go to previous messageGo to next message
coctostan is currently offline  coctostan
My models suggest that a TD10M would be less efficient than the Eminence Delta 10a spec'd by Wayne. This would require a crossover change for sure.
I'm curious if there are any upgrade drivers for the pi7 midhorn. I read your old midhorn thread and you mention the JBL 2012H, but it is no longer available. The JBL 2251J is very similar in spec's but uses a differential drive motor...and it is a 16 ohm driver. I'm curious if you would consider this a good fit for the horn if I were able to alter the crossover of the pi7 myself.
Re: AE Drivers [message #69815 is a reply to message #69814] Sun, 16 October 2011 08:49 Go to previous message
I've always noted my fondness of the constant directivity cornerhorns, saying things like "nothing else can beat this setup." I feel quite strongly that it is the best configuration possible for home hifi or home theater. The only downside is that not all rooms can support this configuration. In fact, most can't. But if you have the right corners, it is definitely the way to go.
As for the midrange drivers in the midhorn, the Delta 10 is very good in this application. I don't think much of the Delta 10 as a midwoofer (like would be required of a two-way) but it's excellent as a midrange driver, especially when horn loaded. Midrange horn loading leverages its strengths without being burdened by any of its weaknesses. Horn loading reduces excursion and its natural low-pass function attenuates cone breakup. So more expensive drivers tend to gain less, and ironically, sometimes don't even work as well.
No other drivers are suggested for the midhorn in the seven π cornerhorn. We used the JBL 2012 as an upgrade option for a while, but honestly, it didn't gain much for the price tag. A horn loaded Delta 10 does as well as the 2012 did to around 800Hz up, and actually performed better above that. Horn loading reduces excursion and its natural low-pass function attenuates cone breakup.
Previous Topic: One- Pi crossover tweeking.
Next Topic: Attention Everyone: Post Pictures of your 3pi speaker here
Current Time: Thu Nov 12 03:16:05 CST 2026
