Home » Sponsored » Pi Speakers » Speaker placement and wavefront launch (A visual representation on how walls affect the wavefront)
Re: Speaker placement and wavefront launch [message #69734 is a reply to message #69732] Thu, 06 October 2011 14:46 Go to previous messageGo to next message
skywave-rider wrote on Thu, 06 October 2011 11:35
In some of the examples you posted above a distorted wavefront close to the speaker eventually attains a spherical shape at a distance. How can the wavefront become "aligned" like that? I always thought the wavefront very close to the speaker would remain the same propagated out into space if there are no reflections.
I have two answers for you, one that you asked for and the other, you didn't.
First is the reason sound waves become spherical at a distance. All sound waves in free space tend to radiate this way, even if they start off as a plane wave (like from a vibrating piston) or are fragmented by reflections, diffractions or whatever. At some distance - again, in free space - they'll tend to form a spherical radiation pattern. The reason for this is superposition, a sort of averaging mechanism that forces them into this wavefront, the natural propagation mode of sound in free space.
Now the second answer, also related to superposition of waves. The same property that causes the wavefront to "settle down" into a spherical pattern at a distance is also what causes it to become distorted by self-interference, room modes, diffraction and refraction. When a wavefront encounters a disturbance like a sharp edge that causes diffraction or an object that refracts part of the wave, then a new vectored wavefront forms with a different trajectory, sort of a new virtual source. When a boundary reflects a wave, then it also can be seen as a virtual source. And of course, other (physical) sound sources create wavefronts of their own too.
All these kinds of things combine by superposition to create a wavefront that is anything but spherical. That's what makes the jagged looking wavefront, and it's what creates room modes and self interference notches. It's the mechanism that creates vertical nulls too. So the same thing that makes a wavefront spherical at a distance is also what makes it fragmented in the presence of interference.
Inside a room, the truth is the wavefront doesn't keep the spherical expansion even from the most perfect sources. The best case has a direct wavefront expansion that is spherical until it reaches the opposite walls (or furniture, people, cats and dogs). Boundary reflections create wavefronts that interact with one another to form a complex modal "checkerboard pattern" inside the room. The checkerboard pattern is "pockets" of peaks and nulls, positions where the sound is loud at a given frequency right next to adjacent positions where sound pressure level is low.
The shape of the modal pockets and their size and position are determined by frequency and positions of sound sources, reflectors, refractors and diffractors. At high frequencies, the pockets of energy are so closely spaced that they average together. Several of them span the distance between your ears, so they sound like a uniform sound field. At lower frequencies, the pockets are larger, wide enough you can move a few inches and pass between a high energy and low energy position. These larger modes become more noticeable. That's why we look to multisubs and flanking subs to help smooth this frequency region.
The thing that's nice about constant directivity cornerhorns is two of the most audible and troublesome self-interference problems are eliminated at the source. The reflection from the wall behind most speakers almost always makes a deep notch in the midrange, but there is no reflection from that wall when constant directivity cornerhorns are used. There is no horizontal self-interference, whatsoever, because the source is acoustically close to the walls all the way up through the midrange. And the midhorn and woofer overlap in the 100-300Hz range, which tends to smooth vertical modes. Where self-interference between the floor or ceiling reflection and one source causes cancellation, the other source being in a different location, fills it in. So the response is very good from about 100Hz upwards. No need for flanking subs with this configuration, although more distant multisubs can be employed to smooth lower frequency room modes.
When I use three π or four π loudspeakers, I usually accompany them with flanking subs. Most installations cannot be done with them quite as close to the wall as I'd like, because they're physically large speakers. I usually put them on stands about 12" to 15" up, and toe-in 45° like the cornerhorns. This prevents me from putting them as close to the wall as I'd like, but the midwoofer isn't much further than two feet from the wall behind them. I put flanking subs on the floor, one beside each main, and push them back against the wall so they are offset in all three dimensions - several inches below, several inches behind and several inches beside. Each sub is run with the same signal channel as the main it is flanking, low-passed fairly high with a gentle second-order slope. I usually low-pass around 100Hz, and with a second-order slope, there is a fairly good amount of overlap up through the next octave, smoothing the lower midrange band.
Re: Speaker placement and wavefront launch [message #69754 is a reply to message #69734] Sat, 08 October 2011 15:30 Go to previous messageGo to next message
You've given me a lot to think about. Thank you.
I just did the water experiment, where I instigated 2 waves in a pool of water; where they converged I noticed an "adjustment" of the wavefront. Superposition I guess.
I'll have more questions. Very Happy
Re: Speaker placement and wavefront launch [message #69761 is a reply to message #69754] Sat, 08 October 2011 23:13 Go to previous messageGo to next message
It's neat stuff. The thing is, when you have constant directivity cornerhorns setup, you really get to hear what constant directivity sounds like. The sound field is uniform through the entire audio band, and the wavefront is unperturbed. Nothing else does it. Not dipoles, not planars or electrostats, not two-way waveguides, nothing.
I've seen a lot of my colleagues claim that constant directivity is most important above 1kHz. It's not true, it's just convenient. In fact, I think it's arguably more important to have controlled directivity in the low midrange, because that's where the nasty vertical modes, floor bounce and back wall bounce do the most damage. Those are probably the most important regions of the spectrum, and yet they are overlooked by many.
Then again, the flanking sub or helper woofer approach does work very well at smoothing that range. It's not like it can't be dealt with using more traditional speakers. But still, if you have a chance to use constant directivity cornerhorns, you'll see what I mean. There just really isn't anything like them.
Re: Speaker placement and wavefront launch [message #69769 is a reply to message #69761] Mon, 10 October 2011 09:33 Go to previous messageGo to next message
I agree on the importance of the low midrange. Thanks for the informative wave images.
Re: Speaker placement and wavefront launch [message #69771 is a reply to message #69769] Mon, 10 October 2011 10:00 Go to previous messageGo to next message
Wayne, I think you should send me some 7Pi cornerhorns to "validate" your theory Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Re: Speaker placement and wavefront launch [message #69790 is a reply to message #69771] Tue, 11 October 2011 21:31 Go to previous messageGo to next message
Hi Wayne, Right after you send some to Shane, would you send me a pair to ,........
BTW, I working on a write up on how dipoles work in rooms from a practical aspect. When I fiddled with the math on them it will drive you crazy Rolling Eyes as it indicates that they can't work at all most of the time, between direct and reflected sound particularly in the lower mids there is no hope. Fortunately, in real rooms they don't seem to exhibit the problems to that degree. Tall ESLs like I have tend to have an advantage over some conventional designs as they act a lot like a line source. There are smaller reflections off the ceiling and floor. With the curved radiating surface it most likely has an effect on how they react in rooms vs the math. Wayne might have the answer there. Smile I suspect that they act more on average power at a closer distance than conventional ones as opposed to the near field aspects that were in earlier posts.
Re: Speaker placement and wavefront launch [message #69794 is a reply to message #69790] Wed, 12 October 2011 00:19 Go to previous messageGo to next message
Most of the dipole and planar folks I know tout the side-cancelling nature as helping reduce side wall reflections. This is true, since they have what is effectively about 120° radiation, and there is very little radiating straight out to the sides.
The problem is this doesn't actually help much on the side walls because there is still plenty of energy at wide horizontal angles. And of course, you have the whole rear wave to deal with. That's why I think they sound best when pulled far away from walls.
One place I find planars to sound really great is when they're up close, set just ahead of me, and angled in towards me. They have great imaging that way. But that arrangement sort of kills the room, making it unsuitable for anything else. Push the speakers back into a position where there is still usable living space in the room and the sound is terrible. They're like a beautiful girl that's way too tempermental to actually live with.
One of these days, you'll have to check out some constant directivity cornerhorns. If you have the right corners, they are all pluses, no downsides. They just plain do everything right.
Re: Speaker placement and wavefront launch [message #69797 is a reply to message #69660] Wed, 12 October 2011 10:46 Go to previous messageGo to next message
Hi Wayne,
Do the 7pi have the mid bass and low midrange punch that the 4pi have? I see that the 7pi is a little more efficient. But you don't have the 15 JBL playing the midrange with the 7pi like you do with the 4pi.
This is a great thread.
thanks.
Re: Speaker placement and wavefront launch [message #69798 is a reply to message #69797] Wed, 12 October 2011 12:48 Go to previous messageGo to next message
Absolutely, the woofer in a constant directivity cornerhorn runs up to around ~300Hz, with a gradual first-order rolloff. It overlaps with the midhorn from 100Hz to 300Hz, smoothing the vertical modes. It gives a full, rich body to the fundamentals in that region, most noticeable in vocals, and instruments like piano, guitar and cello.
Note that middle C is 260Hz, which marks the approximate point where the woofer is starting to rolloff. The octave below that is covered by both midhorn and woofer. Below that, it's pretty much just the woofer. You don't need flanking subs with a constant directivity cornerhorn, because it is sort of built-in. There isn't any rear or side wall reflection, and the vertical modes are smoothed by the overlap between midhorn and woofer. The lowest frequency modes can be smoothed with distant multisubs, but flanking subs just aren't required with this configuration.
icon14.gif  Re: Speaker placement and wavefront launch [message #74628 is a reply to message #69660] Wed, 28 November 2012 11:54 Go to previous message
Now this is what I call a great source of information. Great visuals with just as good text to back it. Excellently detailed all the way around. Great job.
Previous Topic: Which Pi for me?
Next Topic: H290C dimensions
Current Time: Sun Nov 08 17:26:12 CST 2026
