Home » Sponsored » Pi Speakers » Contemplating a change
Re: Contemplating a change [message #69417 is a reply to message #69416] Fri, 09 September 2011 10:00 Go to previous messageGo to previous message
Thanks, Wayne! And I assume I should try to lengthen the port to get closer to the size you're using? On the way to work I was thinking my internal volume of the cabinet is going to be even more off because your design has the horn in the cabinet and mine sits on top. I may try to do a bit of cuttin' & drillin' to fit the horn in the cab and reposition the port. Any issue with port on the back if I have to go that route?
Previous Topic: New HT - Need Advice on Speakers - 4pis or 7pis for main, 2pis, and what to use for bass
Next Topic: Discussion on waveguides / horns
Current Time: Tue Nov 03 12:28:04 CST 2026
