I'm in the process of deciding how many 4Pi mains to build for my home theater. I can't decide between two or three. I can't wait to hear everyones opinions building two will definitely be cheaper, so how much better will it sound with a 4Pi center channel?
petew Messages: 77 Registered: June 2011 Location: Albuquerque, NM USA
Give us some specifics about your room and other gear. Are you using a projector? What size is your room? How many seats?
Phantom center works well, but anyone sitting way off axis will not get the "effect". The fours have a wide sweet spot, so depending on the specifics of your setup, two may work great.
I currently have my theater setup in my living room. I have a 50" plasma, and two couches, but will be remodeling later this year and do a DIY screen with projector and individual seats. I will probably have six seats as there is normally only three of us that watch movies together on a regular basis. My room is 19' x 22' x 10'.
Do you think two 4Pis will work while I use the plasma, and add a third when I do the projector setup? I don't foresee the seating positions ever being really wide (probably 2 rows of 3 seats). Maybe I won't even see the benefit of a center with narrow setup?
Wayne Parham Messages: 19105 Registered: January 2001
Our plasma TV is 50" also. The speakers are outside that, angled in as described in the "High-Fidelity Uniform-Directivity Loudspeakers" whitepaper. There is absolutely no need for a center channel using this setup. Personally, I wouldn't even consider a center channel unless the seperation between R/L channels was greater than 20 feet.
Wayne Parham wrote on Fri, 02 September 2011 22:59
Thank you for the clear and succinct response, Wayne! I'm happy to hear this and only build two as that will reduce the costs by 50% ! I need to rereading that Hi-Fi Uniform Directivity Loudspeaker whitepaper again.
