Home » Sponsored » Pi Speakers » 1pi or 2pi for surrounds?
Re: 1pi or 2pi for surrounds? [message #69207 is a reply to message #69206] Sat, 27 August 2011 08:48 Go to previous messageGo to previous message
I built mine fully except left the baffle off. Once I got my speakers I marked the spots for holes and used a drill press for the "T"nuts for the woofers. I had my inulation in at that point also. I then fine tuned if you would the cut out for the port and installed the port from the back side of the baffle making sure it was flush with the outside edge of the baffle. When I made my baffles I slightly oversized them in case my boxes were a bit out of square. I then installed the baffles and flush cut them with a router.
Previous Topic: Flanking subs and phase
Next Topic: Pi 3 or 4?
Current Time: Mon Oct 19 21:45:51 CDT 2026
