Home » Sponsored » Pi Speakers » Midrange Horn
Re: Midhorn Flat Pack Tips [message #69159 is a reply to message #69157] Wed, 24 August 2011 13:37 Go to previous messageGo to previous message
The Miller dowel pins are included. They're just sitting in throat hole cutout, sandwiched in between side panels. If you use them to pin the horn together you won't need to cradle the horn while the glue sets. Just put white glue on every surface, assemble the horn and tap the pins in.
Previous Topic: How good is the 1Pi? Pretty good, I think.
Next Topic: I covet the 7Pi Plans...
Current Time: Mon Oct 19 15:42:56 CDT 2026
