Home » Sponsored » Pi Speakers » Start with a standard Pi ...
Re: Start with a standard Pi ... [message #68936 is a reply to message #68932] Tue, 09 August 2011 06:02 Go to previous messageGo to previous message
Maxjr is currently offline  Maxjr
I just had an idea that might make this idea more realistic. It sort of goes back to my other post about modifying the 3Pi box while keeping the same internal volume and vertical alignment with woofer and waveguide.
What do you think if I make the width and height of the 3Pi box the same as the 4Pi, and make the depth longer to make up for the larger volume of the 3Pi. Then, when I have money saved for the JBL 2226H, I can just cut off the entire baffle and excess part of the box on a table saw. This will allow me to reuse 3/4's of the box (the sides and back). This will also allow me to make the 3Pi baffle closely along the same lines of the standard 3Pi with the same vertical alignment/distance of the waveguide to woofer and port.
Previous Topic: 4 Pi Speaker Plans
Next Topic: 7Pi in unusual room
Current Time: Sat Oct 24 23:01:27 CDT 2026
