Home » Sponsored » Pi Speakers » 4pi Commercial Dinner Theater Build
Re: 4pi Commercial Dinner Theater Build [message #68680 is a reply to message #68679] Fri, 22 July 2011 10:40 Go to previous messageGo to previous message
I will be using T-nuts. On my first F20 build, I accidently stripped one of my T-nuts when installing the driver. If you know anything about that cabinet you know that there is NO space for hammering a T-nut after it is built. After removing the driver to replace the damaged T-nut, I found that vice grips worked at replacing the T-nut very well. As a matter of fact, it worked better than hammering it in since you can apply even pressure to seat it properly, as opposed to trying to hammer the edge of a baffle cut-out.
I am not certain how the front panel being installed is going to hinder the installation of the insulation? I used a jig saw to cut my circles. Can you post a picture of the router you are talking about?
Previous Topic: Audition in Austin
Next Topic: $5 drivers as computer Pis
Current Time: Fri Oct 30 08:28:03 CDT 2026
