Home » Sponsored » Pi Speakers » 4pi Commercial Dinner Theater Build
Re: 4pi Commercial Dinner Theater Build [message #68649 is a reply to message #68648] Tue, 19 July 2011 18:24 Go to previous messageGo to previous message
If I understand your questions correctlly this is my answer. You cut the port material to the length needed IE: 3 1/2". The actual port cut out is just a hair bigger than the 2 1/2 diameter. I cut a 2 1/2 hole and then when I got the port material I used my dremel with a sander tip and opened it up just enough to get the port in. I then coated the end edge of the port with some PL (I used PL on all my 2pi and 1pi cabs) and slid it in even with the baffles front.
So long story short cut the port to 3 1/2" and slid it in all the way through the front/baffle until it reaches the outside edge.
Previous Topic: Audition in Austin
Next Topic: $5 drivers as computer Pis
Current Time: Fri Oct 30 09:36:55 CDT 2026
