Home » Sponsored » Pi Speakers » Modifed 4 Pi Build Report (Design)
Re: Modifed 4 Pi Build Report [message #68571 is a reply to message #68570] Sat, 16 July 2011 00:03 Go to previous messageGo to previous message
This is a picture of a web clamp being used on the base. There is also a press clamp shown:
index.php?t=getfile&id=555&private=0
This where I am now:
index.php?t=getfile&id=556&private=0
I am almost ready to apply finish. The speakers just need some wood filler and finish sanding. I also need to fill the void where the beveled edge meets the base. Overall, there are several defects in the veneer, but I am generally satified with the results. In my oppinion, the huge ports are a bit ugly, but I can live with them. I put a strip of walnut between the cherry veneer and the solid cherry. It may have been better with with more contrasting woods like walnut and maple, but I decided to see what happened. Cherry will darken with time, so the contrast between walnut and cherry will likely fade with time. I really like the cove molding on the base. I was done by creating a table saw fence that ran at about a 20 degree angle to the saw blade. There may be sound issues from the cavity beneath the speaker, but I will deal with it.
Future posts:
-Finished speaker
-Sound testing I borrowed a high quality microphone from work. I plan to test at least for frequency response. If the room response testing works, I will report on that also. I plan to use Arta Software for the testing.
Previous Topic: Setting 4pi LCR upside down in theater?
Next Topic: Looking for a few extra watts for your Pis?
Current Time: Tue Nov 03 11:44:49 CST 2026
