Home » Sponsored » Pi Speakers » Excited =)
Re: Excited =) [message #68518 is a reply to message #68496] Thu, 07 July 2011 22:48 Go to previous messageGo to previous message
Bill,
I may start my build post this weekend, even though the speakers will not be fully complete. I have 8 clamps like the ones you are talking about. They are made by Jorgenson. You are right about the force needed. The glue bottle says one should have 100-225 psi of force. I reached 10 psi if lucky. I think the clamp force is closer to a vacuum press, which could never exceed 14.7 psi (atmospheric pressure). I would definately try the glue you recommended next time. Since you have clamps already, the press that I designed may be at least worth considering. I will probably add 4 more clamps for my next project. Trying some fancier veneers like you use would be interesting. I like zebrawood, but I have never found the right project for it. With the clamps, I might be able to experiment on small projects.
Previous Topic: PI4 Build for home theatre
Next Topic: Any Pi builders in Ireland ?
Current Time: Mon Nov 23 00:06:44 CST 2026
