Home » Sponsored » Pi Speakers » towers (which way)
towers [message #68499] Thu, 07 July 2011 10:29 Go to next message
Dpend is currently offline  Dpend
should the fronts of the cabinet be between the sides or on the face so the sides are hidden. Or does it not make any difference
Re: towers [message #68500 is a reply to message #68499] Thu, 07 July 2011 14:31 Go to previous messageGo to next message
I always put the face and rear over the sides, with the tops and bottom inside all four. I think it's structureally stronger, easier to glue-up without fasteners, and especially, the top and bottom pieces help square the glue-up. On top of that, if you cut 3 extra top and bottom pieces per cabinet, you have ready made, exact size braces.
index.php?t=getfile&id=541&private=0
Re: towers [message #68506 is a reply to message #68500] Thu, 07 July 2011 19:29 Go to previous messageGo to next message
Thats an excellent idea the braces would be the same size. thanks for replying. I just came home with the would today. I found some 5/8 shelving panels already veneered for less than 14.00 and there 96 inch long.
Re: towers [message #68514 is a reply to message #68506] Thu, 07 July 2011 21:51 Go to previous messageGo to next message
breakfastchef is currently offline  breakfastchef
I agree with Bill Epstein; the front should over the sides. For super easy glue-up of the front and rear panels, I used biscuits. Everything lined up quickly providing me ample time to install clamps and wipe glue drips.index.php?t=getfile&id=544&private=0
Re: towers [message #68516 is a reply to message #68514] Thu, 07 July 2011 22:46 Go to previous messageGo to next message
Thanks guy's I love seeing the pics,
really helps out. They go straight to my thumb drive
Re: towers [message #68517 is a reply to message #68514] Thu, 07 July 2011 22:48 Go to previous message
By the way how do they sound?
Previous Topic: 2 PI upgrade
Next Topic: glue
Current Time: Mon Oct 12 12:43:42 CDT 2026
