Home » Sponsored » Pi Speakers » Excited =)
Re: Excited =) [message #68486 is a reply to message #68256] Tue, 05 July 2011 23:37 Go to previous messageGo to previous message
You made really quick progress on those. They look good.
As far as the gaskets, what Wayne said should work. I took Wayne's advice from a previous post about using a shower liner gasket from Home Depot. That seems to work well also.
I know that you said that you said that you are considering options for finishing. From what I have seen of your design, I would recommend a 2 ply veneer if you decide to finish them with a wood veneer. I (stupidly) decided to use strips of wood veneer and splice them together myself. I did that a long time ago when stock veneer was thicker and it worked well. To replace what I screwed up, I bought a 2 ply veeneer. It was very stable and not prone to wrinkling or bubbles. I wish the entire covering of my speakers were covered with 2 ply veneer. I put the final sheet of my spliced veneer on this weekend. There is no photographic evidence of the botched attempt.
Previous Topic: PI4 Build for home theatre
Next Topic: Any Pi builders in Ireland ?
Current Time: Mon Nov 23 00:04:21 CST 2026
