Home » Sponsored » Pi Speakers » 3pi, smaller cab possible?
Re: 3pi, smaller cab possible? [message #68434 is a reply to message #68431] Sat, 02 July 2011 10:32 Go to previous messageGo to previous message
I've sent plans to your email address.
You can route to recess the woofer and the tweeter or surface mount both of them. Just don't do one and not the other. As long as they are both flush or routed on the baffle, their depth (distance from the listener) the same, i.e. one won't be further than the other, which would angle the forward lobe up or down.
Also, maintain the same vertical distance between the woofer and tweeter. For example, don't move the tweeter up outside the box unless you move the woofer up a distance to match. I don't think that's in the cards for you, but it might be worth saying, just in case.
Previous Topic: 4 Pi plans
Next Topic: 3pi sub
Current Time: Tue Nov 03 05:08:39 CST 2026
