Home » Sponsored » Pi Speakers » Pi 2 towers with H290 - doable????
Re: Pi 2 towers with H290 - doable???? [message #68400 is a reply to message #68395] Thu, 30 June 2011 12:29 Go to previous messageGo to previous message
The problem is you can't match the directivity of the Alpha 10 with the H290 horn unless you use the midhorn. I mean, you can use the crossover rolloff to "squeeze" the pattern, but you can't get a good acoustic directivity match unless you use the horn.
Previous Topic: dummy load
Next Topic: Since I don't have enough complexity in my life...
Current Time: Sat Sep 05 10:22:03 CDT 2026
