Re: 4 Pi Home Theater Build [message #68285 is a reply to message #68284] Tue, 21 June 2011 22:36 Go to previous messageGo to previous message
It's hard to say what they'll encounter. I've had some packages arrive undamaged, and very little packaging would have probably been needed. Then I've had some packages hit on the side so hard with what appeared to be a dagger or rod of some sort - went right through and damaged the contents beyond repair. I've seen some tube amps that were packaged with several inches of foam in place surrounding them - dropped so hard that internal bracing shifted under the impact load. No scratches on the outside because of the foam, but it was obvious that the box had been dropped a great distance.
Can you palletize the boxes? In my experience, this seems the most reliable. Maybe it's because they can easily manuver the package with a forklift, I don't know. But I've had consistently good results with palletized packages.
Current Time: Sat Nov 21 21:04:56 CST 2026
