Home » Audio » Group Build » New Projects
New Projects [message #67885] Fri, 27 May 2011 21:58 Go to next message
Hi Everyone, After retiring about 4 weeks ago Very Happy and then going to the LSAF, my month has been shot. However.... partly because of requests at the LSAF and partly because I want everyone to be able to listen to quality tube audio I will shortly start to post projects and links to some I have done in the past year or so. It will take a few more days to get going on this. Secondly, I will be posting under my sponsored portion of the site (Oddwatt Audio) the instruction manuals for the current kits which are all derived from my diy projects. This will give you an opportunity to decide if you want to roll it on your own as a diy project or feel more comfortable with a complete kit. So stay tuned as here is where the diy ones will go.
Re: New Projects [message #67902 is a reply to message #67885] Sat, 28 May 2011 22:15 Go to previous messageGo to next message
Hi Everyone. Sooner than I thought.... Rolling Eyes
http://www.diyaudioprojects.com/Tubes/EL84-Push-Pull-Tube-Amp/
This is a link to the project that is now known as the "Series One Poddwatt" If you have questions on how to do the build let me know. I have some new things to try on it and will pass them along as I perfect them.
Re: New Projects [message #68423 is a reply to message #67885] Fri, 01 July 2011 22:17 Go to previous messageGo to next message
Hi All, As promised, check out the phono preamp I posted in the Thermionic section. Warm up your soldering irons every vinyl lover should try one. Parts are off the shelf to hold the cost down and the biggest problem is layout and care in construction as it is a high gain device.
Re: New Projects [message #99592 is a reply to message #68423] Thu, 16 July 2026 09:21 Go to previous message
Hank is currently offline  Hank
gofar99 wrote on Fri, 01 July 2011 22:17
I've been following your works here, and you are doing great! Is there any new stuff in the block? Would want to follow up on progress.
Previous Topic: Planning on building a hifi rack, need suggestions.
Next Topic: How often do you have group builds?
Current Time: Thu Nov 12 08:48:09 CST 2026
