Other than just building another 4pi speaker, are there any plans for a horizontal center channel speaker that sounds good with the 4pi speakers? Hopefully it uses the same horn driver as the 4pi speakers. Thanks!
If quality matters, then horizontal layouts are out. You can't make a good speaker with drivers that are side-by-side. It's a matter of directivity, and the fact that such a speaker would have nulls to the left and the right instead of above and below.
The only reason anyone ever makes a speaker like that it is convenient with respect to physical layout. You can make it short, so it can easily sit under a TV set. But the truth is, it's worse than no speaker at all. If you are limited in the vertical size, it is better to use a phantom center channel. Toe in the left and right as suggested, and you'll have a very realistic center image.
I would not suggest the use of a center channel speaker unless the screen is physically large, so much that the center has a hole without it. But screens that size get into the realm of projectors where you can put the speakers behind the screen. Then the size of the center isn't a problem, and you can use the same speaker as is used on the left and right channels.
