Sub woofer Assist [message #67350] |
Sun, 01 May 2011 16:46 ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
![](/forum/images/custom_avatars/3806.jpg) |
gofar99
Messages: 1939 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi Everyone, I do tubes , so speakers are a bit out or my field of smarts . I have 2 pairs of sub woofers, both 15 inch and would like to put one set or the other to work in the 50HZ and down range. Crossovers and power to drive them are not issues. That part I can do. If you all would put on the thinking caps and see what thoughts on how to get the best from either set it would make my day.
Set one: 200WRMS,Le 2.4mh, Z 4, Re 3.7, Fs 33, Vas 4.42 (cuft), Qms 3.40, Qes 0.49, Qts 0.43 Xmax 3.5mm SPL 95db/2.83 v at 1 meter
Set two: 350 WRMS, Le 3.08, Z 8, Re 5.2, Fs 22, Vas 8.79(cuft), Qms 8.92, Qes 0.63, Qts 0.59, Xmax 14.3mm, SPL 88.2 1W/M.
Any thoughts would be helpful. No I can't cut holes in the walls (they are brick on two sides. Not the ceiling either as it has radiant heat tapes.
