Home » Audio » Craftsmen » Sealing MDF
Sealing MDF [message #67275] Thu, 28 April 2011 12:14 Go to next message
I am in the process of constructing three 4 Pi speakers out of 3/4" MDF (with a 1 1/2" front baffle - depth adjusted to account for internal volume decrease).
I am moving soon to a very HOT and HUMID environment (Cambodia) and understand that MDF is moisture sensitive. Therefore, I plan to seal the enclosures inside and out with two or three coats of Zinsser BIN primer/sealer to help with moisture resistance and to harden the enclosure. I will be covering with paper-backed red oak veneer via the hot iron method.
Will the BIN primer/sealer cause any problems with applying the veneer? I will be using Better Bond Heat-Lock Veneer glue.
Thanks,
VIRIBUS MARI VICTORIA
Re: Sealing MDF [message #67284 is a reply to message #67275] Thu, 28 April 2011 21:13 Go to previous messageGo to next message
If using MDF as described I'd apply veneer inside and out with contact adhesive which is one of the few water-proof glues.
OTOH, given a choice in Cambodia (!), I wouldn't touch MDF and go straight to Marine Plywood made with water-resistant adhesive.
Are we talking the Cambodia formerly ruled by Pol Pot and currently at war with Thailand? We Americans are really zenophobic and this one is having a hard time picturing a high-end sound system there.
Re: Sealing MDF [message #67285 is a reply to message #67284] Thu, 28 April 2011 22:06 Go to previous message
Yep, that Cambodia! I will be there for two years. Not sure about my housing - but I am fairly hopeful it will be air conditioned.
Already have the MDF all cut ready to glue (will use Titebond II). I am hoping that by using a shellac-based sealer/primer both inside and out of the cabinet the MDF will be adequately protected from moisture.
I have no experience with veneer and the hot iron method seems to be the easiest. However, I could paint as I would not be going for a piano gloss finish.
Previous Topic: Veneer advice
Next Topic: Veneer advice (contd)
Current Time: Wed Aug 07 18:12:54 CDT 2024
