Home » Sponsored » Pi Speakers » 4Pi metric adjustments
4Pi metric adjustments [message #67163] Fri, 22 April 2011 03:53 Go to next message
Frihed89 is currently offline  Frihed89
What are the proper thickness dimensions for plywood in metric sizes?
Do I have to make some adjustments, for example for the baffles, or do I just stick with "inches" measurements?
Re: 4Pi metric adjustments [message #67164 is a reply to message #67163] Fri, 22 April 2011 08:04 Go to previous messageGo to next message
There's a link to a converter program that will help you convert inches to millimeters on the π Speakers website. Scroll down to the bottom of any page and you'll see the link.
Accuracy to the nearest available millimeter is all that's required. You can use 19mm wood stock in place of 3/4", for example. Even 18mm is fine.
Re: 4Pi metric adjustments [message #67166 is a reply to message #67164] Fri, 22 April 2011 13:49 Go to previous message
Thanks, it was the woodstock size I was interested in.
Previous Topic: 3Pi - 4Pi In Nearfield, <7 feet?
Next Topic: 2pi speakers
Current Time: Tue Oct 20 04:34:55 CDT 2026
